POTATO DIGGER CHAINS
swampchicken
09-04-2004 17:38:49
does anyone know where you can find the links for the chain that shakes the dirt from the potatoes im not shure what make it is but i have seen same type chain on alot of old diggers yhis one is 24" wide.
Handyman
09-05-2004 20:57:33
 Re: POTATO DIGGER CHAINS in reply to swampchicken, 09-04-2004 17:38:49
If you cant find any locally there are several manufacturers you can try contacting. Acme mfg, Broekema Beltway, and Noffsinger Mfg can be found on the internet they make both hook and belted chain but you will probably have to order enough chain to replace all your chain instead of just getting a few links but that is usually the best way to go anyhow
Txsprigger
09-05-2004 18:40:45
You might try Bermuda King in Kingfisher, OK. They use potato chains on their sprig diggers, various widths. www.bermudaking.com
riverbend
09-04-2004 19:42:38
Try Roeter's in Michigan or Market Farm Implement in Pennsylvania. You will need to know the length and the diameter. Last ones I bought were about $2 per link.
Greg
Jim in michigan
09-04-2004 19:09:13
Look on the chain, it should have a number, take the number to pretty much any good ag supply place and you will find the chain,,,Jim
marlowe
09-05-2004 16:56:27
 Re: POTATO DIGGER CHAINS in reply to Jim in michigan, 09-04-2004 19:09:13
a potato digger chain is like no other chain and they don't have a no. on them
