Oil coming out loader filler tube
Tim in Iowa
09-02-2004 12:29:43
I have a Koyker K utility loader mounted on an IH 240. Loader works great but sometimes if I raise the bucket high under load (like when pulling fenceposts), a stream (like maybe 3 or 4 oz.) of hytran oil will spurt out of the filler tube when I lower the bucket. Should I be concerned about this? The oil also looks cloudy. How do you check the oil level on a loader anyway? I wrote Koyker but they were out of manuals for this model.
Paul Janke
09-05-2004 07:01:12
 Re: Oil coming out loader filler tube in reply to Tim in Iowa, 09-02-2004 12:29:43
A leak in the suction line to the pump or a bad seal in the pump allowing air to be sucked in can cause this. So can a too long or too small diameter suction line.
TimFL
09-02-2004 13:28:06
It may be the wrong type of oil in the system. Sometimes hydraulic oils a prone to foaming in certain applications.
Tim in Iowa
09-02-2004 14:16:09
 Re: Oil coming out loader filler tube in reply to TimFL, 09-02-2004 13:28:06
Thanks. That's certainly possible, since this was a used loader and I've never drained/refilled it.
