Hesston PT-10 Help???
Jeff From WI.
09-01-2004 16:37:40
Hi, My gear box just went out on my PT-10? How tough is it to change or fix? Thanks Jeff.
Randy-IA
09-05-2004 16:19:00
 Re: Hesston PT-10 Help??? in reply to Jeff From WI., 09-01-2004 16:37:40
Hi , If you want a parts machine go to www.deeimp.net they have one for $250 as-is . I found it on Iron search and it was just updated on 8-30 so they should still have it . No pt-10 machines turned up in the search in WI. at all ! They are located in Waukon , IA which is in northeast IA . I thought this might help . Good luck ! Randy-IA
Harold Hubbard
09-02-2004 04:09:12
It's been a while since I did it, but as I remember it is pretty straightforward. The outboard shaft support bearing is the worst hangup. I wound up torching it apart since it needed replacing anyway. It's a little bit of a Chinese Puzzle to get the box out of the frame, but after you do that the box itself is pretty easy to repair if all you need is bearings. If anything else is wrong it would be easier and probably cheaper to find a parts machine. The gearbox is reversible for 540 or 1000 RPM PTO, so be sure it goes back in the same way it came out.
