Danuser Post Driver Stuck
tginVA
08-29-2004 09:51:58
I borrowed a Danuser PTO operated post driver. After driving about 15 posts the driver wouldn't raise, I removed one shim from each of the four bolt positions holding the wheel to the frame and it worked wonders for the next 15 posts. I then stopped to mark the rest of my fence line. When I started back (after about an hour), the driver would neither lift nor fall (it was stopped in the "hold" position, not resting on the removable safety pin at the bottom of the slide). Note: I did not leave the PTO running as I moved from post to post. Any suggestions?? I finished the fence line using my digger but would like to get this driver fixed so I can return it.
