Best time to plow with 310 disk
Anthony
08-28-2004 15:22:51
Before a rain are after a rain & how long do you wait after a rair, if so? chiseled it first plow it twice with the 310 & 4230 3 plow time the 310 sinks & pulls a bit harder the old tractor get a bit warm just tring to get some oats in september Thanks
paul
08-29-2004 21:06:47
 Re: Best time to plow with 310 disk in reply to Anthony, 08-28-2004 15:22:51
Kinda confused, is the 310 a disk plow, or just a disk?
It all just depends on your weather, sun, clouds, amount of rain, humidity, soil type, wind, previous crop, amount of trash (old vegitation) on the soil surface, etc. Disking when the ground is wet makes a plugged up disk & a brick-hard ground - much worse & bad in clay, pure sand won't matter much. Otherwise, practice & find out what works.
But, are you plowing with a plow, a chisel plow, a field cultivator, or a disc plow? I'm really confused at what you are trying to do.
Generally you want the ground level & weeds dead, no need to chisel plow, bottom plow, and disk 3 times as it sounds like you are doing?
--->Paul
