implements
dap
08-28-2004 09:13:33
About 20 years ago, I purchased what the seller called a "slusher" for about $100, but damaged it badly digging a pond, and left it when I moved. The man I purchased it from has passed away, and I have not been able to find any info on it. I hope someone can help?
It looked like a steel barrel cut in half and pulled sideways with a drawbar. There were rope actuated levers that allowed the barrel to either roll behind the tractor, or lock in either digging, carrying, or backblading position. I believe it was about 5" to 6" wide, and took a lot of hp to pull.
I dug a pretty good sized pond with it by adding a long drawbar which allowed me to back the "barrel bucket" into the hole. Pulling it back out is what took the hp, but once full, the bucket could lock in "carry position allowing the dirt to be transported away from the hole.
Occasionally, it would snag a stump or large rock, and sheer off one of the bolts that locked the bucket from rolling. I learned the hard way that these shear bolts were intended to protect the bucket. Got frustrated with replacing them so often, and used a grade 8 bolt. Fortunately, this was toward the end of my project.
Does anyone have info, photos, or a source for one of these buckets?
Don-Wi
08-28-2004 22:56:17
 Re: implements in reply to dap, 08-28-2004 09:13:33
yep, Tumblebug. We hav one out back made by Sears Roebuck, The lever's been rusted for years. Some day I want to pull it around and heat it with the torch, see if I can free it. It's only 3 ft. wide.
Donovan from Wisconsin
Don-Wi
08-28-2004 22:55:39
I Bleed Green
08-28-2004 10:43:52
I know what it is. (Tumble bucket)
Or as John Deere called it a (Rotary farm scaper) I have a 5 foot John Deere. We used it allot years ago. They also made a 4 foot. Other companys made them in 4, 5, and i think 6 foot. If you look to the left of this web site home page. You will see Galleries. Look at Implement photos. I think i remember seeing one on there.
greenbeanman in Kansas
08-28-2004 15:53:53
 Tumblebugs and Fresnos in reply to I Bleed Green, 08-28-2004 10:43:52
We shared one with several neighbors. We called it a "Tumble-bug" and also at times a "Fresno".
One of the neighbors had it last and basically inherited it. The son still has it though doesn't use it.
Here is a link for Fresno information.
Link
Schmidty
08-31-2004 16:55:58
 Re: Tumblebugs and Fresnos in reply to greenbeanman in Kansas, 08-28-2004 15:53:53
I think were talking about two different types of scrapers here. I have seen both. The "slusher" or "slush bucket" is about he size of a real man"s wheelbarrow with handles in the same place. Used primarily for creating or re-opening ditchlines, tile lines or run-off"s, it required one man and one horse or two men and a tractor to operate. The tumblebug (at least the one I saw on a heap) resembled a long cylinder and rotated with the wheels after a lever was tripped to empty the contents. Probaly better suited for driveway or road work. I always called the one on the heap a pay-scraper for lack of a name. Thanks for enlightening me. I should buy it and get it "un-stuck".
Schmidty
