IH 5' disk--Charles S.
jackmcg
08-27-2004 06:15:28
This is in reply to a posting sometime back by Charles S. who was looking for replacement bearings for a 5' IH disk. Don't know if they're available from Case IH, but King Kutter uses a very similar bearing on its angle frame disc harrow. I saw it at TSC just the other day and you can order parts on line. www.kingcubber.com You'd probably have to swap out both the bearing and the spacer as they're probably not an exact replacement for what you have. Should work though. I had the exact same problem but modified my old parts to accept ball bearings. Not a particularly easy fix and it requires machine tools--lathe to turn down the spacer and a mill/boring machine to bore out the bearing housing to accept the ball bearings.
Good Luck!
jackmcg
08-27-2004 13:42:13
 Re: IH 5' disk--Charles S. in reply to jackmcg, 08-27-2004 06:15:28
Sorry, that website is www.kingkutter.com
....blasted fat fingers...
jackmcg
08-27-2004 13:37:40
