#55 IHC chisel plow
Chuck
08-25-2004 21:06:53
Help! I found a #55 IHC chisel plow for my 560D, but now I would like to find an owner's manual for the implement. I searched the "Manuals" section of YT to no avail. Any ideas from anyone? I'd appreciate any help you might be able to give.
Thanks. Chuck
RobN
08-26-2004 07:33:21
 Re: #55 IHC chisel plow in reply to Chuck, 08-25-2004 21:06:53
I"ve used one of these for many years but it"s one of the few implements I don"t have a manual for. They"re tough, pretty basic and ag wreckers can likely find you shanks if you need one. The draw pole design is the only weak point about them that I can see - the angle irons can crack where they attach to the frame. I wouldn"t be surprised if yours has been repaired there. Good luck with it.
Kerwin Kilian
08-26-2004 06:26:27
You could contact Binder Books, they do a lot of IH reprints. Otherwise, look on ebay periodically to see if there's one available. I've found several more obscure manuals that way.
Case IH might still carry a reprint as well, you'd have to check. I bought one through them for my 300U but the quality was pretty bad; ended up buying one from Binder. Hope this helps.
