New Holland 67 Baler Question
JeffK-MN
08-23-2004 16:51:45
What is the best way to pull the plunger out to replace the bushings?
Is there any tricks? Thanks Jeff
Steve from New Holland
08-24-2004 04:56:40
 Re: New Holland 67 Baler Question in reply to JeffK-MN, 08-23-2004 16:51:45
Jeff, this is not a difficult job. Prop up all the haydogs. Remove any wedges bolted to the side of the bale chamber. Remove the 2 bolts from the arm that pushes the plunger back and forth. Any pry bar or reckon bar will prove to be adaquate to remove the plunger out the back. Steve
08-25-2004 04:39:20
 Re: New Holland 67 Baler Question in reply to Steve from New Holland, 08-24-2004 04:56:40
One follow up comment: Is this a Super 67 or a regular 67? The Supers had roller bearings and the regulars had wood slides. The Super will be easy to put back in, but the regular with new wood blocks may cause you to lose your religion. Steve
Kelly C
08-24-2004 04:58:37
Its the, Getting it back in thats fun!!
Kelly C
08-23-2004 21:13:46
third party image
Check out my web site. 67 is pretty much like a 68.
John in IN
08-23-2004 18:35:20
I used a winch I had fastened to a draw bar of tractor. A come-a-long would work also. It isn't as bad as you would think. Take out anything in the chute that will create a problem and pull. Good luck.
John
