Mounting a 237 JD picker ????
Kyle
08-20-2004 19:47:48
found a JD 237 mounted picker I would like to mount it on my A john deere its a 1943 Hand crank i was wondering if it is possible to mount it on a hand crank tractor????? also any idea one of these things weight???
Allan in NE
08-21-2004 06:59:17
 Re: Mounting a 237 JD picker ???? in reply to Kyle , 08-20-2004 19:47:48
Hey Kyle,
Yes, your power-trowl should lift that heavy old honker just fine.
But, oh my goodness. Aren't you really opening up a can of worms with the starting issue?
There just is NO room in there with that picker mounted. And gettin' down to those pet-cocks is gonna be another treat!
Tryin' to help,
Allan
Greywolf
08-21-2004 05:00:29
The hydraulics that are needed are through the rock shaft. Had a B and 60, never an A, but the B had the rock shaft so I assume the A will too.
Can't answer about the hand crank for sure, but, mounted on the 60, there wasn't any clearance anywhere for hand cranking.
It's still taking up a spot in the shed, haven't used it for over 30 yrs.
Heat Houser
08-20-2004 20:35:00
You will need hydraulics. I think that it will mount OK but I don"t recollect that the 237 had a provision to allow for hand cranking. You could always park it on a hill and coast start it or pull it with another tractor to fire it up.
Don"t know what the weight is but an A will handle it very well.
Kyle
08-20-2004 21:02:39
 Re: Mounting a 237 JD picker ???? in reply to Heat Houser, 08-20-2004 20:35:00
Will the power trowl on an A JD work to lift the picker???
