hydraulic question
partimer
08-20-2004 07:50:35
I have an aftermarket 3-point hitch on my super m. It utilizes the transmission belly pump for pressure but only has one 4" cylinder on the lift. I can raise a 1000 lb bale of hay but not the 1500 lb bales. My question is, if I add an additional 4" cylinder using the same pump, will my lifting capacity increase by 2 or do I need an auxillary pump to increase the pressure to the cylinder that is already there?
paul
08-20-2004 08:53:57
 Re: hydraulic question in reply to partimer, 08-20-2004 07:50:35
Twice the ram area = twice the lifting force. It will move 1/2 as fast.
--->Paul
Half Fast Idea
08-20-2004 16:09:33
 Re: hydraulic question in reply to paul, 08-20-2004 08:53:57
Paul is correct.
JDB
08-20-2004 10:28:03
Pauls got it right
