Ford 501 Sicklebar Mower Conversion
Roger, VA
08-19-2004 08:19:52
I have a Ford 501 sicklebar mower and want to use it on my 3 year old New Holland TN 70 tractor. I've heard that some folks make conversion kits for this purpose (longer arms? wider clamps...) Help!!
OGGIE
08-29-2004 18:11:43
 Re: Ford 501 Sicklebar Mower Conversion in reply to Roger, VA, 08-19-2004 08:19:52
You don't need those clamps on a tractor with arm stabilizers.Just take them off and fix something to attach the tension arm to, I use the hole in the lower end of the left lift rod. You will probably have to adjust the spring.
OGGIE
08-29-2004 18:11:27
chief 83
08-19-2004 23:07:54
Just change your lower arms out with those for an 8N. I do it every year and only use them for the mower. It's pretty fast and much easier than converting anything on the 501--pretty inexpensive too!
