NH 311 315 balers
JJ
08-17-2004 19:08:11
Opinions on these machines? What does each run for strokes per minuete? What is the capacity of both machines? Draw backs on either?
thanks
jj
ohio
Larry S.
08-18-2004 09:27:08
 Re: NH 311 315 balers in reply to JJ, 08-17-2004 19:08:11
Back somewhere in the early 80's I ran a 311 with a kicker behind a Case 430 gas. Never had any problems, except as with all older NH feeder fork balers, they make "bananna bales". If you spend some quality time with the adjustments they work fine. I have been running a 316 since the mid 80's and also a 540 that is about 6 years old. The 316 has been rock solid. Do the PM and make the adjustments and it just goes and goes. I did motify the location of the first bale wedge in the chamber due to the bananna bales. This modification has worked excellent for our usage, have not had the B'bale problem in over 4 years now.
