ih 46
twosiloranch
08-17-2004 08:02:36
finaly got the 46 working well sat afternoon .baled 180 bales with only two knots coming loose.but i had to put in 2 new rolls of twine,i tied them on as shown and they fed in well.the packaging said it was 190 twine but i was suspicious because it just looked smaller than the other, it didn"t tie 1 in 10.so i quit for the evening it was to late to go get any and get back before the dew set in. put the same twine that was working before and reset everything back where it was.left side is doing ok right side the knot is hanging on the billhook.i adjusted it everyway from loose to fairly tight to no avail.the left side is tight with no up and down movement of the billhook assy the right side has some slack in it verticaly or up the shaft could this be a problem.anyone got a manual on this thing on the knotters.any help appreciated
bub
08-19-2004 18:36:37
 Re: ih 46 in reply to twosiloranch, 08-17-2004 08:02:36
I have a 430 and when I first tried it I had trouble but took sisal twine out and put in plastic and away we went. old twine had collected moisture and swelled. I had an old baler man check it out and he changed two cutters i think under the head and has worked fine since. I got books from ih dealer about 7 a piece
buff_man
08-17-2004 17:27:11
still have that 46 parts baler if you are interested. Drop a Email at [email protected]
Tim IN
08-17-2004 15:01:46
I also recommend the knotter service manual from binderbooks. The Operators Manual also gives good information on common problems. I believe that there is an Operators Manual currently on Ebay. Sounds like you have tried adjusting the billhook cam pressure. I would also suggest the twine tension wingnuts in the twine box as something to try.
Devin
08-17-2004 13:45:06
I just bought a knotter manual from Binder Books for under $10.00. I am sure it will be helpful when I get time to use it. If you get a chance email me at [email protected]. I would like to pick your brain a little as I am just beginning to repair and old model 46. Thanks.
Devin
