494A vs. 1240 Planters...What's Your Opinion?
Kerwin
08-17-2004 07:35:24
Thinking of getting either a JD 494A or 1240 corn planter in the "offseason" and am looking for opinions on either. I have heard that the 1240 plateless might work better with today's hybrids than the plate planters. But, also wonder if repair costs might be more for a 1240 because of the plateless design. What are all of your thoughts?
Just looking for something easy to maintain, 38" rows, for several acres a year. I'm pretty sure I can find either at a decent price because of my location (SW WI).
R-man
08-22-2004 05:04:24
 Re: 494A vs. 1240 Planters...What's Your Opinion? in reply to Kerwin, 08-17-2004 07:35:24
Kerwin, I have a 494 that I used for 6 years when I had a produce business.Planted sweet corn,green beans, pumpkins, etc. with it. Great machine. I modified the boxes so I could plant 30 inch rows. I have a big stack off plates for it. I am just east of Janesville. Could be yours cheap.
R-man
08-22-2004 05:03:59
Thresherman
08-23-2004 20:38:59
 Re: 494A vs. 1240 Planters...What's Your Opinion? in reply to R-man, 08-22-2004 05:03:59
get hold of me, I might want it, im outside milton
R-man
08-24-2004 14:37:16
 Re: 494A vs. 1240 Planters...What's Your Opinion? in reply to Thresherman, 08-23-2004 20:38:59
Thresherman, How do I contact you?
bill from wisc
08-18-2004 06:30:30
I have owned both and now own a 7000. For the moeny invested a 1240 plate planter with double disc openers will do you very good.The 1240 doesnt have a gear box only spockets, less to worry about to go wrong. Make sure you keep the knock out roller and parts in the bottom of the seed box in good shape and you'll have good results.I am keeping my 1240 for a backup to the 7000. I really like my 7000 but then again I have ten times the moeny invested into it then what I have invested into the 1240. Keep your eyes open and youll end up with enough plates that you could plant any size of seed out there. good luck
bill from wisc
08-18-2004 06:29:41
Leroy
08-18-2004 05:40:41
The 1240 plate is the same as the 494A only with new numbers
Mike2222
08-17-2004 09:57:21
I had a 494A, was a good planter, used it @38" x 4 row, did about 50 acres a year. Keep the markers out of the trees and you will be alright.
JR
08-17-2004 08:30:55
They are both good planters,and not much difference in them, the 1240 is a newer model. I had a 1240 plate type so I don't know about the plateless 1240, but have heard they had problems with them. I now have a 7000 with finger pickup units and they haven't been any trouble. I would most likely go with the plate type unless the plateless was a finger pickup type. I would also want double disk furrow opners on it.
