Smaller round baler
HobbyFarmerInWI
08-16-2004 20:06:43
Can you pull a smaller round baler with a 35 hp tractor?
If so, what would you suggest?
Thanks
Burrhead
08-17-2004 14:07:27
 Re: Smaller round baler in reply to HobbyFarmerInWI, 08-16-2004 20:06:43
I run an 845 New Holland with a Dexta Ford @34hp.
farmer mike
08-17-2004 07:14:56
I pulled a Vermeer 504 with my Allis Chalmers WD (35 hp) for years over some steep ground. If you get one of these balers & don't have enough HP, you can have the gear box rotated 90 degrees which sets up the machine for a 1000 rpm PTO. When you use this with the 540 PTO it turns much slower, but with much less effort. I now have a Vermeer 403, which I use with a 65 hp tractor. I like the smaller bale, and I would think this would be a good set up for you. Again, the gear box rotation could be done if you wish. Mike
BUD
08-17-2004 03:58:01
I PULL A CASE IH WITH MY GST 4310 KUBOTA ,38 PTO HP. BALER MAKES A 39"*54" BALE . MY HAY GROUND IS FAIRLY FLAT ,HILLS REQ. MORE HP.I HAVE PUT UP 12 BALES PER HOUR IN A RUSH. I RECOMEND THIS BALER ,WORKS GREAT.C&C MACHINERY HAS A DRUM MOWER THAT REALY DOES THE JOB.GOOD LUCK, BUD
