MF 12 Baler
Melanie Smith
08-16-2004 00:14:04
Having some problems with the baler. Worked just fine all week and part of today but then stopped knotting and just cut all the string (no knots) on right side only. Someone borrowed my manual so I am unable to trouble shoot the problem. I know something is out of adjustment. Need some input please. Checked tension of string. It had this problem before when I used twine then converted to plastic and problem went away for this year up till now.
RobN
08-16-2004 08:04:50
 Re: MF 12 Baler in reply to Melanie Smith, 08-16-2004 00:14:04
Emailed you pertinent manual pages - HTH.
agrogers
08-16-2004 06:26:40
First thing I would say is the bill hooks. My father played with our #10 for 15 years, and when I first started to tinker with it, I replaced the bill hooks(@ $108.00 apiece). He couldn't get it to tie on either side persistently, and I have baled 900 bales with it so far without a miss-tie.
Other possibilities:
-Tension on cam arm for bill hook is too loose or too tight. The book says to thread the nut and tighten it 4 1/2 turns.
-The primary and secondary twines not centered in bill hook jaws. Get two cresecnt wrenches and a screw driver and play with the position of both the twine holder disc drive gear and the twine holder disc until both twines are centralized in the bill hook.
-The stripper arm knife is out of adjustment. there should be a hairline between it and the twine holder disc when the stripper arm begins and ends it's cycle. If not, loosen the bolts holding the knife to the stripper arm and adjust it accordingly.
-The twine holder arm is not holding primary twine against the bill hook. It could very possibly be that the nut that hold the position of the arm is loose, and the arm isn't moving when it should.
Question-
Does one of the ends of the untied twine have a twist in it?
Alex Rogers in MD
Melanie Smith
08-16-2004 13:10:28
 Re: MF 12 Baler in reply to agrogers, 08-16-2004 06:26:40
Found out some of the problem was the spring had come off of the stripper arm (at least that is what I call it). Plus the stripper arm seems extremely wiggly (not like the other side). Alhtough I did not mess with that. It started to work (tied) and I baled about 10 or 15 bales then the spring came off again and I never got it to tie again. I tried to adjust the wiggly stripper arm (sorry for the description) by adding a washer to snug it up a bit but that did not help.
