john deere mod 66 hyd/trip rope lift plow on steel
mark720
08-15-2004 19:18:24
this plow is a unique plow it works and plows fine but the trip clutch seems to give a little trouble. we took clutch apart and everything seems to be in good order but when you trip to lift it gets bottoms out of ground but won"t lift completly up just acts like clutch slips??
Bob Collins
08-16-2004 05:48:33
 Re: john deere mod 66 hyd/trip rope lift plow on s in reply to mark720, 08-15-2004 19:18:24
Mark, When you say the clutch seems to slip, does the land wheel skid along the ground? This is usually caused by having too little tension on the lifting spring or because it is broken/missing. This is the large spring that attaches to the frame and the land axle. If that is not the way your plow acts, give us a bit more description of the problem. bob
