Grease fittings on model #46 baler?
Brent
08-14-2004 07:29:04
I cut some hay the other day and my round bakler went down. I had a little left and I aksed my neighbor's wife if I could borrow his square baler to bale it up. (He was out of town). I took it home and checked the fluid levels greased etc. There were no grease fittings on the U joints on the drive line. I think only one had a fitting and it was where the shaft rides on the carrier aatop of the tongue. Are these original equipment and if so why don't they wear out?
JB
08-18-2004 09:06:07
 Re: Grease fittings on model #46 baler? in reply to Brent, 08-14-2004 07:29:04
Hi, the #46 baler we had back in the 1960s had grease fittings on all U jionts and plunger shaft at both ends.
Possibly cost optimized in later production models?
JB
speedway square baling
08-14-2004 22:55:21
the 46 came out with grease zerks,, now if the u joints have been changed at the local parts store
you can almost bet that they don't have zerks,, an easy way to add them is to drill & tap with the cheapest zerk possible
Devin
08-14-2004 12:11:06
Brent,
I am beginning to restore a model 46 and it doesn't have any grease fittings on the U joints either. I don't know why. I just looked at it yesterday when I was cleaning it up for the first time. I hope to get an answer to this question too. Take care.
Devin
jimont
08-14-2004 14:19:51
 Re: Grease fittings on model #46 baler? in reply to Devin, 08-14-2004 12:11:06
I'm not aware of the lack of grease fittings, but thought you both should be aware that 46's were notorious in this area for breaking plunger cranks. Otherwise, they were a much better, faster baler than the older 45's.
