new holland 1045 bale wagon
mike j
08-13-2004 16:45:47
anyone ever used one of these it should have had a v4 wisconsin in it stock and i could see that being a power problem this one has had a chevy 6 put in it kinda rough but mech fairly solid i can fix most anything that needs it just courios if anyone here has used one thanks mike
mike j
08-15-2004 23:26:54
 Re: new holland 1045 bale wagon in reply to mike j, 08-13-2004 16:45:47
Well i bought it its an ugly cobbled up thing but it loads hay great but i need some advice on stacking (tricks or helpful hints) this machine does not do a tie teir so on my 2nd load i put a tie at level 4 and 8 worked better but still wants to lose several off the top when i dump 3rd load i went level 5&8 but still not right any info would be great thanks mike
Hayfarmer
08-13-2004 21:50:21
Have worked around them. The wisconsin engine was anemic. Guys who owned one of these said they might as well have a pull type wagon as they always had to have a tractor around to pull them out. Believe they hauled 55 bales at a time,might vary with size of bale. They did not have auto tie tier like the later wagons.
RJ-AZ
08-13-2004 18:26:34
Neighbor I mechanic for on weekends has one with a cobbled in Ford V8. It still works real good. I put an electric fan on the radiator on a thermo-switch and a manual bypass switch.
Ken Macfarlane
08-16-2004 05:38:47
 Re: new holland 1045 bale wagon in reply to RJ-AZ, 08-13-2004 18:26:34
I have 0 experience with balewagons but I have read you use poles to prop up the pile when unloading? Would this help you?
Ken
