MOCO or Haybine horsepower
Bkeepr
08-13-2004 07:58:19
Right now I cut hay with a sicklebar and a separate crimper. Need the crimper for one of my fields, like it for the others.
I'd like to move to a single mowing-crimping machine, but have a low-horse (8N in good shape) tractor with no chance to get a bigger one. I don't want to spend much money, either.
Can I do that? If so, what type machine and size should I consider?
thanks for any advice,
Tom A
Hugh MacKay
08-14-2004 03:02:22
 Re: MOCO or Haybine horsepower in reply to Bkeepr, 08-13-2004 07:58:19
Bkeeper: I along with quite a few of my neighbors each bought 9' haybines in the 1960's. At the time most of us were using 30-40 hp tractors. We thought they worked well. Within a few years most of us had bought 50-60 hp tractors and we really found out what makes a haybine work well.
No the 8N will not handle the haybine 7 or 9 foot. Most of the others have given you all the reasons. 8N was a great little tractor with a 7' sickle mower. I'm afraid if you put it on the haybine, you will be badly disappointed. 50 years ago there were men around, knew how to use a sythe and could mow more hay than you will with the haybine and 8N.
Bill C
08-13-2004 21:13:55
Hi, I have a JD 1217, 1219 and 925 MoCo, all require around 2400 lbs of hydraulics to raise. I have seen serval large tractors that the hydraulics is too week. You can buy a cheap guage at the farm stores and check it. My MF 165 & 135 put out 2800 lb"s. I can pull a 1217 & 1219 with a MF 135D(38HP) with no trouble. Bill
Bryan g in mo
08-13-2004 18:26:56
I don't think your tractor is going to be big enough, I pull a hesston 1071 with a WD-45 with fluid in the tires, that is a 7 foot cut. It is not so much the width of the cut as it is the weight of the machine. I get on a hillside with mine and it will push the tractor. Also the moco that I have has a min HP requirement of 35HP.
Sid
08-13-2004 16:05:46
I am not very optimistic. I won"t say it can"t be done. I would strongly suggest that you try one your tractor before buying one if possible.. I know a guy tried to pull a baler with his. He baled about ten bales then said "that"s enough playing around" and unhooked from it. It might handle a seven foot. But even then with any hill at all it will be a heavy pull by itself. I believe they call for thirty to thirty five HP min. for a nine footer. The fact that it is offset to one side makes for a harder pull than a straight behind the tractor pull. I think the Ford 8Ns are a good tractor and ounce for ounce are just as good as any of them. But just not enough ounces in my opinion.
Leland
08-13-2004 14:50:41
Saw guy around here run 9 footers with a B deere try one out you should be able to pull it .BUT what about hydrolics you also need that also. You have to raise and lower it.
Bernie in MA
08-13-2004 14:06:13
I was in the same position 30 years ago. I bought a 110 Hesston self-propelled mo-co. Paid $1700 then, wore it out, bought another one just like it 6 years ago for $900. It's driven by 5 different belts that are a pain to replace, but I wouldn't mow with anything else. It's powered by a V4 Wisconsin.
EMZ
08-13-2004 13:28:21
I would think your 8N could handle a 7 foot NH haybine or maybe even a 9 foot.
EMZ
08-13-2004 13:26:14
