Old Ford disc
Larry950
08-12-2004 20:30:49
have an old Ford disc and have broken one of the spoollers, the shaft slides through this spooler which is held in place by a collar. Anyone know where I can get another spooller?
jhill
08-14-2004 06:06:14
 Re: Old Ford disc in reply to Larry950, 08-12-2004 20:30:49
I would try a New Holland dealer. Most of the old Ford stuff is still available.
jimont
08-13-2004 05:52:43
I think you'll find it's a White built disc and parts should be available at an AGCO dealer and maybe even TSC.
TomTX
08-13-2004 05:30:38
Need more info. Model. Offset, tandem, plow, etc.
Larry950
08-13-2004 12:20:58
 Re: Old Ford disc in reply to TomTX, 08-13-2004 05:30:38
The disc has a plate on it that says Ford it is a 10"wide double ganged disc. Will White disc parts work?
Leroy
08-15-2004 08:03:43
 Re: Old Ford disc in reply to Larry950, 08-13-2004 12:20:58
Probably not as probably made to early and be a lot lighter weight version but that spool unless it is a bearing spool could be a universal part avaible from most makes, just measure the axle diameter and length and at a parts yard you may find one to fit
