Need to buy a sickle mower.
Rickstir
08-12-2004 10:55:10
I have a '53 Jubilee. We want to start cutting our hay. This will be a "community project" in that friends have the rake and bailer (square). I need to find a sickle mower but don't have the slightest idea which brand will work with the Jubilee. Any and all suggestions will be appreciated. Thanks.
stan
08-15-2004 16:17:56
 Re: Need to buy a sickle mower. in reply to Rickstir, 08-12-2004 10:55:10
Get one that was made to work with your tractor. Like Jim from Utah said, the JD #9 is a nice cutting little mower and we've used it the last 4 years. But, mounting it on our old Case VAO is at least an hour job every time and took some creative rigging to get to hook on at all. Similarly our Farmall A came with an IH mower, but it was worn out and again is an hour or more to mount. Just found a Case #10 at auction and hooking it up to the old case was a revelation. Hookup took five minutes at the most and everything made sense and fit. No wiggling jiggling and haywiring things together. So, a long way to go to say buy one that was made to work with your tractor. Happily hooked up in WA
Stan
JohnG
08-13-2004 08:31:33
I have an MF 7' mower for sale. What part of the world are you in?
Tony Cotton
08-21-2004 14:05:24
 Re: Need to buy a sickle mower. in reply to JohnG, 08-13-2004 08:31:33
I have a MF 41 sickle mower and need the pulley off the gear box. I would like to buy another MF sickle mower and/or pulley asap!
Gary V
08-16-2004 14:40:12
I am looking for a MF 31 mower. Just wondering what you have.
Rickstir
08-13-2004 09:18:34
I am in North East Missouri
havvey
08-12-2004 13:14:22
the deere 350 or nh 450/451 are two of the best right now most others are older so condition and parts are key. i dont personly like the newer sitrex where both knife and cutterbar move but they work well in hay.
John (MO)
08-12-2004 12:35:08
The Fords mentioned below are good little mowers. But so are several other brands. Condition is really important. Better to get one that has been taken care of and stored inside rather than one that has been setting in the barn lot for several years. Usually better to get a belt drive than a stick, but stick movers have mowed millions of acres, so if you should run across one in good shape and at a good price, don"t not consider it. Also if you can get an extra sickle for the mower, then you can have one to sharpen or repair while using the other one.
Kelly
08-12-2004 12:25:13
 I have a Ford sickle mower for sale in reply to Rickstir, 08-12-2004 10:55:10
I have a ford sickle mower for sale in central Kansas $300. E-mail if interested
L. Lee Saunders
08-20-2004 07:06:03
 Re: I have a Ford sickle mower for sale in reply to Kelly, 08-12-2004 12:25:13
Where in central Kansas? What is the length of the bar? Is it 3pt?
paul
08-12-2004 11:49:15
Trailer sickles will also work, if you have a port for hydraulics as most of these require a cylinder.
--->Paul
Jim.UT
08-12-2004 11:43:29
Any 3 point mounted sickle mower will work for sure. I use a John Deere #9 on my Ford 850. Other possibilities would be a Ford 501 or 515. I recently saw a Massey Ferguson 31 that was a 3 point mounted mower. I thought it might be for sale, but when I went back I was told they were keeping it.
I have only used the JD #9 so I can't comment on the relative pros and cons of the various possible choices. I have no complaint with the JD.
Bkeepr
08-12-2004 12:08:06
 Re: Need to buy a sickle mower. in reply to Jim.UT, 08-12-2004 11:43:29
I've got an 8N, predecessor to the Jubilee. I use a Ford 515 sicklebar for hay, which was designed for these tractors. Hook-up is a bit awkward at first, but it mows fine and is easy to take care of. I picked mine up at auction for about $400; later got offered another for $150 by a guy who was tired of tripping over it in the shed. If you get one of these, call New Holland and buy the owner's manual it will help you a lot getting started.
Tom A
