when to bale
Two Silo Ranch
08-12-2004 08:12:58
I need to cut and bale a few acres of good bermuda this week.Our normal temp this time of year is the mid 90 range.We are having an unusually cool month.the high for the next 3 or 4 days is the 76 to 82 range.Do i need to adjust my lay time to compensate for the temp.does the temp have a direct relationship with the quality of the hay.If you let it lay untill its all brown is that bad ? Should it have a mixed coloration of tan and green and feel dry?What are some rules of thumb .small squares by the way.may cut this evening . Thanks Jeff
Leland
08-12-2004 22:44:23
 Re: when to bale in reply to Two Silo Ranch, 08-12-2004 08:12:58
Are you putting in small bales or big bales if you are going to round bale it you can get away with putting it up a little damp. They do it up here all the time bacause it is so humid up here. but it's 40 at night now so they are giving it a couple of xtra days here also. You always can buy 50 lb bags of table salt and spread it on hay as you put er in shed.
txblu
08-13-2004 06:53:09
 Re: when to bale in reply to Leland, 08-12-2004 22:44:23
Have heard mention of salt lots lately. How does the animal react to the salt treatment of the hay?
I know cows like to lick salt, but what about your horse customers?
What happens chemically to the hay as a result of the salt?
(Boy you gotta lotta questions..... .yeah; curious)
Thanks,
Mark
Leland
08-13-2004 14:42:12
 Re: when to bale in reply to txblu, 08-13-2004 06:53:09
Never put much thought into it. It helps cure it kind like salted meat helps finish drying and you don,t have to use that much. Add to much and wires will rot quickly but it never seem to bother cows or horses and I never noticed any mold from wet hay.
Leland
08-13-2004 14:42:06
kyhayman
08-12-2004 11:56:45
Ambient temperature directly effects curing time. The lower the temp the slower the evaporation rate. Extra curing days wont adversely affect hay quality for crude protein or net energy (within reason). Main effects (as previously stated) are loss of color due to solar bleaching and evaporation of dew moisture. This affects the perception of quality, not the actual quality (except for vitamin A, which drops radically with loss of the green color). There is some affect on intake of hay that is discolored over 'nice and green' but once again, this is minimal if not taken to an extreme. If you are raising hay to feed a loss in perceived quality is of minimal concern, if you are selling to a market that buys on appearence then color is THE consideration. There is no 'rule of thumb' that I would trust not knowing your storage conditions. Even experienced operators make mistakes, it's always safer to test for exact moisture content before baling. Even after all this time I've got a barn right now with curing fans running 12 hrs a day b/c I thought I could tell (passed the 'feel test', my meter was in the other truck, and the field was 20 miles from a microwave).
jimont
08-12-2004 17:45:52
 Re: when to bale in reply to kyhayman, 08-12-2004 11:56:45
kyhayman - Many barns have been lost here in Ontario this year due to hot hay. Never seen a year like this in over 40 yrs of haying. Same problem as yours, hay seems to pick up moisture in the barn after passing the "feel" test. So far, we've managed to dodge severe heating and mold only because we only cut a few acres per day.
txblu
08-12-2004 09:53:56
I'm doing just that as we speak. I'm delaying my baling until the hay is cured. I cut day before yesterday and raked yesterday. I raked before it was fully cured to get it up off the ground and let it fluff; allowing the breeze and dry northern air to cure it. Guess it won't be cured till Sat at least.
No one has proven to me that chlorophyll loss (from air/sunshine)has any impact on TDN. It may not be as appealing to horse nut YUPPIES, but not to the horse. KY hayman can probably give you the exact figures on what I'm saying.
If you are really worried about color, get a tedder and scatter the stuff several times. It cures much faster than without one and color retention is much much better.
Don't put it up green (uncured). I define cured as two hands side by side grasping a wad of hay, twisting the wad and on or before the third twist, it breaks apart. If it is still stringy it's too wet.
Good luck.
Mark
