Hayin Leased Land
txblu
08-12-2004 06:48:34
Leased this pasture. Twas in their family for bout 100 yrs and hadn't seen steel in 25 that I know of probably more. Best crop of totally undesirable weeds you would ever want to look at including being sparsely populated...with anything....looked like worn out cotton land.
Got out the plows and chiseled many times till I got down to 12". Then the same with the disc harrow I use for a disc plow, (using 22" fronts) until I could bury to the axle. Came back with the spike toothed harrow and leveled her all out and let it rest for the winter.
This spring I hit her a lick with the harrow and waited till the weeds showed up and hit her with a good dose of 2-4-D. Couple weeks later hit her with 300#/ac of triple 17 with trace minerals then drilled in sudan seed.
First cutting wasn't that stellar. The sudan didn't germinate very well and I noticed Johnsson Grass and Coastal Bermuda shoots and sprigs which is probably why the sudan didn't germinate as it usually does.
Day B4 yesterday, I cut again and I couldn't believe my eyes. From out of seemingly nowhere, the pasture was dense with knee high bermuda and J. Grass to the point where next year I am not going to plant at all; will use the native grasses.
So, you never know what a little TLC will bring you from the soil. I was duly surprised.
Mark
Leland
08-12-2004 22:48:47
 Re: Hayin Leased Land in reply to txblu, 08-12-2004 06:48:34
Just what kinda of concrete to you Texans have to work with? Up here they would give up if they had to make that many passes to make dirt fit to plant.
txblu
08-13-2004 06:57:43
 Re: Hayin Leased Land in reply to Leland, 08-12-2004 22:48:47
Called Houston Black Clay and if you don't hit it in the right window it is either concrete or mud; seems to be no inbetween. But in the summer, with no rain it will grow hay.
Had a neighbor rebuilding his soil with legumes; i.e. Blackeyed Peas. One year he planted and harvested (had harvested, by hand) a full crop WITHOUT ONE DROP OF RAIN. Amazing but true.
Since the land is not that large, I'm hobbying, and it's located right across the street from my farm, I thought it worth the venture. Now that it's done, won't have to do it again.
Thanks,
Mark
Leland
08-13-2004 14:47:18
 Re: Hayin Leased Land in reply to txblu, 08-13-2004 06:57:43
WE have soil like that around here timber soil white as a ghost does the same as your black clay. or go east 60 miles the old praire soil the black dirt is 4 ft deep in places. drop a plow in it you have 1 long strip of turned soil wont break up so thick. but thats what you get for $3500-4000 an acre
txblu
08-15-2004 06:00:23
 Re: Hayin Leased Land in reply to Leland, 08-13-2004 14:47:18
10-4
