spinner seeder/fert units
paul
08-11-2004 23:40:12
I'm thinking of getting one of those cone shaped 3pt spinners. Would like to spread a little fertilizer (like left over starter from the corn) on pasture, other spots. Put down a little oats and/or grass/ clover/ alfalfa seed when it doesn't seem right to pull out the drill...
Odds & ends stuff.
Local store has a Cosmo unit, I see where I can get a Herd unit within driving distance. I'm sure other brands are out there.
Any good, bad, stay away from, or just forget the silly idea I have advise?
--->Paul
thurlow
08-12-2004 06:16:23
 Re: spinner seeder/fert units in reply to paul, 08-11-2004 23:40:12
Have had a Herd King since Fido was a pup; works good. No chart to set flow rate; just have to guess at setting..... see how far the first "hopper" goes and adjust from there. Have sowed a lot of pasture/hay by pulling a "stalk-cutter" type do-all while using the spreader; it throws the seed right into the front of the do-all. Just have to make sure you keep the spreader high enough to keep the spinner out of the hitch..... .
