feed grinder setup
maslo oplatky
08-11-2004 05:11:09
I need setup and engine horsepower/rpm requirement information for a 30's vintage McCormick Deering 10 inch feed grinder..
Thanks. Maslo
JMS/MN
08-11-2004 15:24:18
 Re: feed grinder setup in reply to maslo oplatky, 08-11-2004 05:11:09
If it is a 10 inch IH burr mill like what we had in the 50s, we ran it with a WC Allis-Chalmers. Belt pulley on the burr mill might be an inch bigger diameter than what was on the tractor. Ran it nearly wide open= pto speed.
maslo oplatky
08-12-2004 07:22:21
 Re: feed grinder setup in reply to JMS/MN, 08-11-2004 15:24:18
Thanks for the info..now if i can figure the proper adjustment for the burr and thrust bearing I should be OK...
JMS/MN
08-12-2004 08:20:12
 Re: feed grinder setup in reply to maslo oplatky, 08-12-2004 07:22:21
If you mean how to adjust it for fineness of grind- just turn the cranks tighter to get a finer grind.
maslo oplatky
08-12-2004 19:00:52
 Re: feed grinder setup in reply to JMS/MN, 08-12-2004 08:20:12
Thanks again for the tips.. I hope to get a fine corn meal from the machine. there is a spring that loads pressure on the engaging lever that I wasn"t too sure about, and then the husk cutter bar adjustment. opposite the burr adjustment crank on the clutch yoke is a simple bolt with a jam nut and I assume I would just try to keep it relatively the same length as the adjustment crank bolt so that everything looks square?
maslo oplatky
08-12-2004 18:57:18
