Ford 515 Mower bracket
Susan
08-10-2004 18:32:49
I've got a Ford 515 sickle bar mower - component #14-278 (56"). I need the bracket which mounts the PTO main drive to the lower frame of the mower (the main sheave is also mounted through this bracket). The bracket has two slots which allow it to slide horizontally to adjust belt tension. Can anyone tell me where I might be able to get just the bracket? Any help would be most appreciated - THANKS!
Bkeepr
08-11-2004 04:13:54
 Re: Ford 515 Mower bracket in reply to Susan, 08-10-2004 18:32:49
Have you tried New Holland? I've found they can get almost any part for the old Ford stuff. Sometimes they're very expensive, but most times the prices aren't bad. I'd start with them, if you can't find a junker 515 somewhere.
good luck!
Tom A
