Old wood wagon
Joe
08-10-2004 17:01:31
Hey guys,
I am interested in an old wooden box wagon, has 4 rubber tires with metal spokes in decent shape, wagon has been painted, has the sides that get wider at the top....what should I expect to pay for somehting like this? A couple hundred? I dont know what name or brand it is? LOcated in Ohio.
Thanks, Joe
greenbeanman in KS
08-13-2004 00:54:47
 Re: Old wood wagon in reply to Joe, 08-10-2004 17:01:31
Some of the old "prairie schooners", "conestogas", or other so called covered wagons had flared sides. The name usually is specific to a certain kind of wagon, but has gotten somewhat generic.
You may have such a conveyance that has been converted for parade use or other use with newer wheels.
As an example, we converted a horsedrawn hay rack
to spoked wheels with rubber tires. A local welder did the work. The axles, etc. are still the old wooden ones.
chuck
08-10-2004 18:00:18
it sounds like you have found an old grain box--if the box is solid id say its interesting--i have seen metal ones in good shape bring $200-750. if it has a john deere running gear-it will bring on the upper end--depending on what you want to do with it--would ofcourse deteremine what its worth--
