NH 270 shear bolt - thanks!
brent
08-10-2004 10:22:51
I posted a couple of weeks ago re: shearing the flywheel shear bolt. I sharpened the knives, and it hasn't sheared a bolt since. My wife thought the baler sheared the bolt yesterday, but the bolt's locknut had come off (don't know why), and the bolt backed out enough to disengage the flywheel.
The shear bolt is a 2" long, 5/16-18 grade 2 bolt. The dealer sells them in a pack of 10 (wonder if that's not a good sign...) for 3.60 for the pack.
Again, thanks for the responses. Once we are done with this cutting, I'll pull it into the shop and give it a good cleaning and maintenance.
Hayfarmer
08-11-2004 07:44:16
 Re: NH 270 shear bolt - thanks! in reply to brent, 08-10-2004 10:22:51
If the locknut backed off the bolt I would say either the bolt was not really tight to start with or the flywheel/drive arm bushings are worn badly. Also check bushing in center of flywheel for wear.
