Baler for JD 620
pafarmer
08-09-2004 18:41:23
How large a small square baler can I pull with a JD 620? is a 575 w/thrower out of the question?
What models would you reccomend?
Tim(nj)
08-09-2004 19:50:58
 Re: Baler for JD 620 in reply to pafarmer, 08-09-2004 18:41:23
A 575 needs to be kept full to make good bales, and your 620 doesn"t have enough in it to handle the speed, the windrow size, and the big wagons that you need to efficiently use that baler. In New Holland balers, you"re pretty much limited to a 565.
pafarmr
08-10-2004 04:33:49
 Re: Baler for JD 620 in reply to Tim(nj), 08-09-2004 19:50:58
Tim, thanks for the advice. What New Holland baler would you reccomend in an older baler? maybe a 316? I usually run my 575 with a 4230 jd, but I am looking to have some backup equipment.
