Krause K-20 219 (pic)
Red Raider
08-09-2004 16:05:21
After 20 years of being idle, I brought out my grandpa's disc in preparation for work next spring. Aside from some wear at the guide rod pin on the hitch, cracked hydraulic hoses, and plugged grease zerks, I think we're ready. The bearings for the tie rods turn smooth and no slop. I was surprised to learn that Krause is still in business, in Hutchinson, Kansas. We have two more one-way discs to drag out of the fence row. Both were probably pulled with the Farmall H and F-20 years before that.
third party image
John A.
08-09-2004 20:58:02
 Re: Krause K-20 219 (pic) in reply to Red Raider, 08-09-2004 16:05:21
Red Raider, You must be in the High Plains. Those old, Oneways were every where at one time. I know where many are still in use around Stratford,Tx to Texhoma,Ok. My Brother-in-law pulls 2 16ft krauses with his 4650 JD, on his dryland wheat ground. They stay down on this rent ground that is 6 quarters in size.
A neighbor of his pulls 3 16 ft krauses with a 8440 JD on 3 sections of dry ground.
Thunder, I used to pull a 12 and a 14 with a 4020 DSL, PS. on my realitives dry ground.
They are good ol oneways. Will turn out a lot of work simple to set and maintance.
Have fun. Later,
John A.
Red Raider
08-10-2004 06:00:52
 Re: Krause K-20 219 (pic) in reply to John A., 08-09-2004 20:58:02
Close to the panhandle, but it came from Baylor County (near Megargel), and also was primarly for wheat. The model 219 was the smallest in this series of one-ways.
