Sickle mower swathboard.
John in CT.
08-08-2004 19:38:51
I have a NH 451 that I use for trimming and cutting small areas. I have a metal rod type swathboard and have the blade shoes set in the highest positions. My problem, my swathboard doesn't clean that clean of path for the next time around. Should I go to a wooden one? If my metal rod one can be adjusted, how should I bend the rods? Thanks.
wolfy
08-10-2004 19:10:15
 Re: Sickle mower swathboard. in reply to John in CT., 08-08-2004 19:38:51
Probably mowed a thousand acres with no swathboard. If you drive just right tight the six inches or so that the end shoe gives you is enough. Oh once in awhile a little tall stuff will fall into unmowed stuff-just go a little faster & it will fall backward as should.
Dave H (MI)
08-09-2004 06:43:57
I have not used an all rod swathboard but have a mower now with a small solid metal board with a long rod projecting from it. Can't say as I like it much and will switch back to the larger wooden grass board that I am used to. Wood is still pretty durable and it does a good job.
