Right way to chisel plow in central Texas??????
Anthony
08-06-2004 16:55:13
Got a JD4230 & a 10 shank sunflower chisel with points its heavy duty with a hydralic raiser & lower. The back thirty ackers hasnt been worked in 30 years.want to plant oats & rye in mid sept-Oct.Chiseled today was hard finally got it set right 2-4 inches at a crossed pattern in 2nd gear slow tryed third was ok some it was hard too had to raise & lower the hydralic maybe pull two more chisels off aftre this rains drys up.Whats the best speed & what gear ??For my 4230
txblu
08-09-2004 05:56:12
 Re: Right way to chisel plow in central Texas????? in reply to Anthony, 08-06-2004 16:55:13
Confusing post.
At first I thought you were trying to bust up crusted black clay which is dead slow and lots of weight; making numerous trips to get down to where you want to be. And yes criss-cross x patterns will help. Sometimes I even used the disc first, as a plow to get thru the top 2 inches to more manageable soil, then chisel to 10-12". Course traction on the loose soil is not good. Usually wait for the weather to soften it up for me. August is not a good month to crack new ground.
Then you said something about rain which is mud and totally different. You can't chisel mud. Chisel just cuts thru it like a cake and mud closes behind it after it passes.
Mark
