Wood bearings for discs
George in OhiO
11-28-1998 17:55:35
I am in the process of rebuilding the set of
3-point discs that came with my 8N when I
bought it. The discs have wooden bearings
that are sleeved inside a metal tube between
each disc and there is a grease fitting for lubrication. The existing wood bearings are shot and I was wondering where to look for new ones or if there is some widely accepted substitute?
Thanks-in-advance!
Wayne
11-30-1998 17:28:00
 Re: Wood bearings for discs in reply to George in OhiO, 11-28-1998 17:55:35
: I am in the process of rebuilding the set of
: 3-point discs that came with my 8N when I
: bought it. The discs have wooden bearings
: that are sleeved inside a metal tube between
: each disc and there is a grease fitting for : lubrication. The existing wood bearings are : shot and I was wondering where to look for : new ones or if there is some widely : accepted substitute?
: Thanks-in-advance!
It may be possible to fabricate something out of combine straw walker boxings. If you end up starting from scratch use hardwood
