Hi Phil, Bulding fence out here in NE is as common as breathing....we all get to do it. :>) Forget the electric; you can always add that later if you are running some big bulls who like to 'rub & scratch' the fence and you feel you should have the need. Normally, a 5 strand will hold just about anything except sheep, dogs, deer and antelope. Well maybe not, come to think of it, my first wife escaped all my fencing! :>) If you are putting in a 5 strand, then this is going to be a permanent fence and you want to build it right the first time because nowadays, it is quite costly (believe me). For your runs, set the 6" wooden posts between 16 and 20' apart and plant 'em deep. Any portion of the post higher than the top of that top strand is totally wasted post. In between each wooden post, plant a heavy "T shapped" steel post. This gives you a post every 8 or 10 feet and keeps the stands separated as they should be. The corners are the main issue. They have to be braced and bracketed to stand the load of those tensioned 5 strands. Build these corners with 8 to 12" wooden posts and 6" bracket members. You will have to brace with a "N shapped brace" coming left and a "backward facing N" going right. Then lay an additional horizontal 6" brace across the top of each "N" in between the two posts. (Hope all that makes sense). What I mean is, the top of that corner post needs to be braced against the bottom of another post set in the ground a short distance away from it. This has to be done in both directions on your corners. I would only use full bore barbed wire. Keeps the critters from rubbing on it quite so much. If you build it right and build it strong, it will stay tight and useable for many, many years. Hope this helps a little, Allan
