setting up 3 point brush hog
ags
08-03-2004 14:56:36
When I set up my brush hog cutting about a 5" height with the back of the hog slightly higher than the front the rear wheel barely makes contact with the ground. Is this set up correctly or should the weight of the hog be on the rear wheel?
marlowe
08-03-2004 16:26:23
 Re: setting up 3 point brush hog in reply to ags, 08-03-2004 14:56:36
the weight should be on the rear wheel and the tractor 3pt. lengthen out your top link bush hogs are not made to drage on the ground
