identifing a case plow
c-case
08-02-2004 19:00:44
I aquired a 2 bottom case plow. need help identifing what model it is . the only thing I found on it is case stamped on the top of the frame. any help on this would help.
Thank You very much
c-case
1031D
08-05-2004 22:43:33
 Re: identifing a case plow in reply to c-case, 08-02-2004 19:00:44
Sounds like a Cenntenial plow to me, got 5 of them.
Leroy
08-03-2004 04:18:22
Mounted, pulltype, rubber or steel wheels, clutch or hydrolic lift, resharpen or throw away shares?
c-case
08-03-2004 12:50:17
 Re: identifing a case plow in reply to Leroy, 08-03-2004 04:18:22
sorry about leaveing out the important info.
It is a pull type, rope trip 2 bottom plow. it is on rubber with spoked wheels. I guess they are throw away shares, they are bolted onto the moldboard with 2 bolts, one seems fixed to the share, and the other looks like a normal plow bolt. if there's any other info you may need please let me know.
Leroy
08-04-2004 06:02:44
 Re: identifing a case plow in reply to c-case, 08-03-2004 12:50:17
I wish I could help you on that but I just don't know that much but I thought if I got you to give that information then some one else hopefully would come in with that answer, Leroy
