PT 7 Haybine
Dave H (MI)
08-02-2004 08:30:48
Does this model have a wobble box? Where can I find it and how do I tell if it is good? Any other opinions regarding quality and value would be appreciated. Thanks!
vapet
08-04-2004 07:04:04
 Re: PT 7 Haybine in reply to Dave H (MI), 08-02-2004 08:30:48
Machine has a pitman type drive for the knife which works well. Have had a PT 7 for years with no trouble except for a broken belt tension spring. The pitman drive goes thur a bell crank to drive knife.
Tim IN
08-02-2004 11:15:31
I believe that the gearbox should be located at the back of the machine on the underside of the tongue side. By laying down under the back of the machine and looking above the tire you should see it. This is the case on the PT-10.
Jim in michigan
08-08-2004 13:32:06
 Re: PT 7 Haybine in reply to Tim IN, 08-02-2004 11:15:31
Tim only some of the PT10 's have the gear box,, there are 3 different PT10 series units,, I have the better style that has the top mounted cylinder and no gear box,,,JIm
