loading a drill
rwh
08-01-2004 18:46:25
I have a chance to buy a 10-ft. steel-wheeled Oliver Superior grain drill at a good price but am stumped as how best to load it. The guy selling has a JD 4020 with a loader and I have an Oliver 550 with loader, but I don't know whether either or both can lift the beast high enough to put it on or remove it from my 18-ft. trailer. Anyone have a clever way to load these things?
Del
08-01-2004 20:26:32
 Re: loading a drill in reply to rwh, 08-01-2004 18:46:25
I used one of those for years, still have it put away with a few other pieces I started out with. Due to the steel wheels I hauled it many times to the field on a flat bed hay wagon. I kept two real good planks and would shove it up on the wagon, tie one wheel down to one side of the wagon then push it around and tie the other wheel to the other side, run a chain under the wagon frame through the tongue and far wheel, binder it down hook behind the wheel disc and take off.
BEN in KS
08-01-2004 20:20:05
I just recentl moved a JD 16X8 disc drill. My grandfather bought it new. We pulled it up ramps sideways onto a 16x8 flat trailer. We unloaded it the same way by pulling the trailer parallel into a shallow ditch and pulling the drill off. I would try to use a loader if possible. These old drills are A LOT heavier than they look! Good luck and be careful.
thurlow
08-02-2004 06:56:27
 Re: loading a drill in reply to BEN in KS, 08-01-2004 20:20:05
Our first drill (in the 50s) was model "B"???? JD with galvanized grain box and lever lift. Openers would barely clear the ground. We became very adept at loading and unloading as you describe..... ramps (2 x 10 x 8ft long)and side-ditch; back it on with tractor, chain it down before pulling hitch pin, etc. Did it dozens of times before we got an 8200..... ...bigger tires and hydraulic lift.
Bill2
08-03-2004 19:42:03
 Re: loading a drill in reply to thurlow, 08-02-2004 06:56:27
Wasn't the hydraulic lift a wonderful improvement for drills?? I can't imagine why it took so many years for that to happen. Solved a huge amount of hassles and saved lots of time.
We had a mid/late 60's JD drill, rubber tires, press wheels, and hand levers for lifting. What a pain in the butt! We moved this drill very long distances, so there was no choice but to line up the holes in the press wheels for the steel rods to slide through, so you could raise the press wheels to chain them up. Then the drill was terribly back-heavy. Plus, the disks never cleared the ground very much, so it was always so aggravating to move on gravel roads and lots of highways too.
Best solution I've ever seen for moving any kind of drill like that or a steel wheel drill (plus all kinds of other things you can ever imagine) was the Donahue low-boy trailer we got. The wheels have cog that you unpin and let fall into slots on the inside of the hubs. This locks the wheels, and the trailer will pull forward off the undercarriage that will tilt, and then the trailer floor will be flat on the ground. The trailer's main frame is square box beams, so you only have about 4" or 5" to drive upon. Use some boards to shim that so it isn't so rough if you want. You don't need ramps, ditches, etc. When loaded and item secured, just back the trailer back up onto the undercarriage, release the cogs, and you're off. That's the end of problems moving a drill that won't raise high enough to clear the crown of the road, dealing with raising up press wheels, etc. If you can find a trailer like that, you'll wonder how you ever got along without it. People used to haul 12 row planters on these kinds of trailers before the planters folded hydraulically.
Good luck with the drill.
JMS/MN
08-01-2004 20:19:45
Must be similar to a ten foot Moline. Tip them back, so they rest on the box, and the hitch is vertical. Chain to the hitch and load it on the wagon. Both loaders should handle the load- certainly the 4020. If the drill is a steel wheel- it likely has higher wheels than the Moline, but loading this way eliminates the hitch hanging beyond the trailer edge.
