MF 32 Sickle bar belts installation help
Richard in Texa
08-01-2004 07:28:22
Finally got my new pulley machined so it will fit on my mower. Having a bit of trouble getting the two belts back on. The belts run the bar action.
Seems like I should disconnect the pitman stick so I can get a bit of the belt on the V and then rotate the pulley.
Am I on the right track.Any tricks to this??
Anyway off to tracor supply to get a pin for the pulley.
Bob Semrau
08-02-2004 06:49:18
 Re: MF 32 Sickle bar belts installation help in reply to Richard in Texas, 08-01-2004 07:28:22
Richard, that sounds right. There should also be an eyebolt that you can loosen/tighten to control belt tension.
