Flail mowers
Nathan
07-31-2004 15:59:14
Is a flail mower generally noisier than a finish mower? I am trying out a used one that I found and I can't hear the tractor running when running the flail mower. I think the bearings may be bad.
Thanks
Bob Semrau
08-02-2004 06:51:16
 Re: Flail mowers in reply to Nathan, 07-31-2004 15:59:14
Could some blades be missing ? They make more noise if they're out of balance.
TomH
08-01-2004 18:02:44
If it's just the bearings they should be reasonably easy and inexpensive to replace, just consider the repair in the price. But make sure it isn't the gearbox.
john *.?-!.* cub owner
07-31-2004 19:14:57
The only one I've ever used was Mott Falil mounted on a cub. With good bearings and a good straight shaft (mine was bent when I got it) they are not any noisier than a Woods finish mower.
07-31-2004 19:14:15
dude15
05-21-2006 08:05:34
 Re: Flail mowers in reply to john *.?-!.* cub owner, 07-31-2004 19:14:15
Mower vibrates.The shaft may be bent a sixteenth of an inch.Is that enough to cause a vibration?Any other reason for the vibration? How does one go about straitening the shaft?
Help
Thanks in advance
John
