identify 1940's tractor
Lisa
07-30-2004 11:44:14
My father recently acquired a tractor he is trying to restore but is stuck and would appreciate any info available, the tractor is 6 feet long, the tractor rear wheels adjust in from 48 to 42 inches, the front wheels are 4 feet apart, has planatarys, the front wheel is 3 x 12 -blank, 5 bolt hole, with a 3 inch center, the rear tire size is 750 x 16, the steering wheel is off set to the left, there is Sears tag on the engine that is model 500/308571, serial # 8845, it looks like a Shaw from the 1940's, my father needs a front wheel, coil for the engine and a fuel tank, if any one has any info on the tractor so that we may be able to acquire the parts we would greatly appreciate it, thank you
casey
07-30-2004 14:49:01
 Re: identify 1940's tractor in reply to Lisa, 07-30-2004 11:44:14
no other numbers stamped on the frame anywhere or on the tranny or rear diffy? they could be stamped or cast.
