Gre-sen Hydraulic valve
Randy SE-MN
07-28-2004 13:34:51
Does anyone know if there are rebuild kits for these old hydraulic valves. Any help would be appreciated.
Coloken
07-29-2004 07:27:28
 Re: Gre-sen Hydraulic valve in reply to Randy SE-MN, 07-28-2004 13:34:51
Don't know what yours needs, but I fixed mine with nothing but new "O" rings after a good cleaning with wire wheel. Obtainable most any where. Kind of tricky in the order you do them so not to score them.
Shovelman
07-28-2004 18:14:39
Randy,
Try Baum Hydraulics Company @ (800) 228-9222 or www.baumhydraulics.com
They are very helpful and should have what you need. I recently rebuilt an older 2 spool Gresen valve plus converted it from closed center to open center, added a relief and power-beyond, and Baum had everything I needed in stock. I have always had good luck with them.
Good luck,
Scott Goff
Randy SE-MN
07-29-2004 05:26:09
 Re: Re: Gre-sen Hydraulic valve in reply to Shovelman, 07-28-2004 18:14:39
Hey Shovelman...Thanks a bunch for the info. I don't have it apart yet,hopefully it is rebuildable.
