What differentiates the good square balers from th
marvin
07-28-2004 11:25:33
I was thinking about the different parts of the baler and came to the conclusion that the knotter is the key to a good baler. I came to that conclusion after only putting about 400 bales through my old baler. So what in you mind makes a good baler? Is it the pickup, plunger, feeder into the chamber, knotter, kicker, weight and size of baler?
paul
07-28-2004 21:55:26
 Re: What differentiates the good square balers fro in reply to marvin, 07-28-2004 11:25:33
Knotter.
NH & JD figured them out first/ best, and those balers bring a premium.
--->Paul
kyhayman
07-28-2004 12:21:12
Condition, adjustment, and operator.
Even the best, most modern baler with an unskilled or careless operator wont make good bales. Even a very old baler if it is not rusted, in proper adjustment, with worn parts replaced and a skilled operator who knows how to rake and bale properly will do ok.
In my observations, twine makes more difference than color of the knotter. Good twine, fresh, and dry will solve a multitude of problems. When my dad first bought the 336 JD I've got now new back in the 70's he tried using 9000' per bale twine. Had all kinds of problems. Went to 10,000 and it tied perfectly for 20 years. Dealer recommended the smaller diameter as it flowed better through the knotter mechanism. I switched it to plastic in '95. Did great until late last year and I could not hardly get it to tie a knot. Worse this year, missing everytime the hay got heavy or the least bit out of condition. Knots were loose and pulling apart. Did some adjusting and switched back to 10,000 sisal, no more problems. I've used NH and other JD's. Not much difference in results.
Ken
07-28-2004 12:05:07
For me it would be a host of things, common to all machinery:
reliability
ease of repair
cost/availability of parts
Reliability is important to me as I work full time. I can't spend my evenings and days off scrouging for parts and driving to every little dealership looking for a junked baler.
I've used wide and narrow pickups, do a good job raking and it doesn't matter.
feeder forks are pretty standard, plungers on older machines seems to cause trouble.
I don't use a kicker, our bales are light by most peoples standards.
Knotter is key to the reliability I think. Much of that has to do with maintenance and adjustment.
Mark Goodman
07-28-2004 20:35:59
 Re: Re: What differentiates the good square balers in reply to Ken, 07-28-2004 12:05:07
From my point of view, bailers are a lot like cars. You have to kick the tires, get into the inner working mechanisim (knotter,chains, gears,plungers) and most of all the overall apperance of the bailer. You can't expect to take a rusted mistreated piece of equiptment into the hayfield and go to work. I look for proper grease maintenance and or missing grease zerks, wear on the flywheel, condition of shear pins,(Cold Rolled steel in place of a sheer pin is a bad thing) condition of the PTO shaft.I also try to find out what type of grass this has been bailing and where it has been seviced. Take your time and get a feel for the piece. If a seller is in too much of a hurry for an in depth inspedtion there is usually a reason.If you don't feel good about the piece, walk away. You will be better off in the end. There are no CHEAP repairs on old equiptment like this. As to small square/Big Square VS Round Bale, thats up to you./
