J.D. 1209 Haybine
Nick
07-27-2004 17:36:50
Hi, I have a J.D. 520 . I have a chance to buy a J.D. 1209 haybine at a good price, I have used a no 5 mower and crimper for years. My question,, will that tractor be able to handle the machine.
Thanks Nick
Leland
07-27-2004 19:55:45
 Re: J.D. 1209 Haybine in reply to Nick, 07-27-2004 17:36:50
Pulled one with an M had no problem. keep sickle sharp and you can fly thru thick hay. I think you won't be sorry you bought this haybine
Tim(nj)
07-27-2004 19:40:09
The 520 should run it, but you may have problems with the hydraulic lift. I don't remember what type of system the 520 had, but the 1209 has a big single-acting cylinder that requires a high-pressure supply.
paul
07-28-2004 06:17:02
 Re: Re: J.D. 1209 Haybine in reply to Tim(nj), 07-27-2004 19:40:09
Older versions have 2 cylinders, newer ones went to 1 cylinder.
--->Paul
