vemeer 605H
mike
07-27-2004 14:33:56
Can anyone testify to the reliabilty of this machine? I have an opprunity to buy one for 2500.00 Is that a good price? Anyone with expierence with this machine please advise! Are the parts easy to get? What should i really inspect before buying?
James in NC
07-28-2004 05:33:59
 Re: vemeer 605H in reply to mike, 07-27-2004 14:33:56
Unless it has been in some really ruff spots jump on it like white on rice. As said earlier once dialed in a great baler. Belts, gearbox, starter flaps are the main things to look at other than chains and bearings.
Anthony
07-27-2004 15:05:41
I just bought one this spring.Look at the belts! Look at the gear box for leraks. look at the pickup teeth they are not to bad to replace the bushing on the bars that hold the teeth you have to tear it all part thats what I did. the hydralic ram on mine I replaced it to .$ 5,000 I paid plus put money in mine.THEY work great just took me 2 days to fine the way that old machine wanted to bale hay then it went to town, The rubber flaps the are next to the drum wheel in bottom I had to bring it in to 1 in from flaps so it would not jam the hay & I have to start with a little hay in first tell the bale form then it EATS all the hay up I can goes fast in 4-5 gear in my 4230 & It takes it all IN!Hope these helps you a bit everyone else on here has been so helpful to me . HAPPY BALING ANTHONY
