You do have live hydraulics. Pto is the issue - can we assume you do not have live pto on the little fellow? I run a 7' blower on a 27hp 1720 here in Minnesota. Some would say that is too much blower for the tractor, but it generally works fine because it has a real slow reverse; and it has live (2-stage) pto so I can push in the clutch if the snow piles up behind & let the blower continue to run & clear it out. With a faster reverse, like my 960 has it would not work so well, even tho the 960 has nearly 2 times the hp. Without live pto, every time you push in the clutch the pto also stops, so when the snow builds up, you hit the clutch, & everything stops. Bummer. Doesn't work so well. So, 3pt blade is about all I can think of, loader of course. You can try a blower, but if you don't have a slow reverse and/or a live pto, it will be difficult at least opening up - extra passes you can take a 1/3 - 1/2 swath and it wirks better. --->Paul
