nh 273 sq. baler
Down and Out
07-25-2004 17:33:54
Knotter jammed and now pto turns freely. Did I shear a pin at front of baler? Where is it located? Anybody have any ideas? I ordered a manual last week but has a 3 week delivery.
RickB
07-26-2004 15:02:45
 Re: nh 273 sq. baler in reply to Down and Out, 07-25-2004 17:33:54
39716 is the NH part number for the flywheel shearbolt. About a quarter a piece. Do yourself a favor and get a bag of the proper bolts.
Mike (WA)
07-26-2004 12:30:00
There's a hole through the flywheel, that mates up with a hole in a flange behind the flywheel. Takes a 5/16 bolt, I think (maybe 1/4 inch, can't remember)- get grade 5 bolts (three "tick marks" on the head)- anything softer will just shear as soon as you try to put any hay through it. Make sure you get long enough bolts so that the union of the flywheel and flange is on an unthreaded portion of the bolt. I found the best thing is a bunch of bolts and plastic lined lock nuts, in a bag in the toolbox, along with the two wrenches you'll need and a large nail or some such to push the broken bolt out of the flywheel.
TimS
07-25-2004 20:55:57
Check the flywheel for a small shear pin....at least that is the setup on my JD Baler.
Ken
07-26-2004 06:48:19
 Re: Re: nh 273 sq. baler in reply to TimS, 07-25-2004 20:55:57
I agree, sounds like the shear pin on the back of the flywheel.
