Hey Belleville Niel
Fudd@work
07-24-2004 18:14:01
That rod is 44" from end to end on the #9 mower. Hope that helps. If you realy want, I can take a pix of it and post it.
Belleville Neil
07-25-2004 16:40:52
 Re: Hey Belleville Niel in reply to Fudd@work, 07-24-2004 18:14:01
THANKS Fudd! I'll work to make the hole in the lifting arm 44" from the hole(s) in the sickle bar. I have two holes in the bar on my mower, assuming my new rod will reach both, which hole should I use - the top or bottom(when in transport mode)? Neil
Fudd@work
07-26-2004 16:39:43
 Re: Re: Hey Belleville Niel in reply to Belleville Neil, 07-25-2004 16:40:52
I like the bottom hole the best as it keeps the bar higher and you don't have to watch the end of the bar so close. I have to drive close to tree limbs so I have to watch so I don't cut them off going up the drive.
Belleville Neil
07-26-2004 17:33:36
 Re: Re: Re: Hey Belleville Niel in reply to Fudd@work, 07-26-2004 16:39:43
Thanks Fudd!
